E-Class (W211) 2003-2009
diesel additive
Old Mar 7, 2020 | 03:16 PM
Matteo Sukic's Avatar
w211 04 e220
diesel additive
as the title says should i use diesel additives on my 220cdi 04?
Old Mar 8, 2020 | 11:29 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Depends on the fuel available to you. Given the low sulphur (lubricity) content of USA fuel, I use additive on EVERY tank of fuel I put into my diesel truck and car.
Old Mar 8, 2020 | 12:04 PM
Andre91's Avatar
2012 E350 4Matic
Also depends on how cold it gets where you are. In very cold climates (regularly below -20c or so) an additive that provides protection against the fuel gelling is almost a must.
Old Mar 8, 2020 | 12:50 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
220cdi never made it to America.
When diesel additives are not needed on regural basis, modern diesels tend to gum up intake more than the older ones.
Don't know if your engine has intake flaps, but those are maintenance items on engines above 100k miles.
Latest news say that BG and Liqui Molly makes "miracle in the bottle" who with special procedure can clean the gunk and at the time some stuff is advised inside the tank.
