E-Class (W211) 2003-2009
HELP!!! 2007 E350 trunk problem
Old Mar 12, 2020 | 09:25 AM
Derik Gagnon's Avatar
2007 E350
I have a 2007 MB E350. I got back from vacation to a dead battery. I can’t open the trunk, the manual key and latch don’t work. Any other way to get into the trunk? My back seats don’t fold down either
Old Mar 12, 2020 | 10:42 AM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome!
A good place to ask your question is in the W211 forum, good luck!
Moving to (W211)
Bob
Old Mar 12, 2020 | 02:47 PM
cetialpha5's Avatar
Does the key turn? If it turns, then you need to turn the key one way or the other then open the latch. If you just turn the key and then it back, the latch won't work. It only opens once the key is turned. If the car door opens, you can also use a cigarette car charger. You just need to turn the key to the on position in order for the cigarette lighter to be on to charge the battery.
