E-Class (W211) 2003-2009
Check engine code p0400
Old Mar 25, 2020 | 06:06 PM
György Szabó's Avatar
1999 Mercedes e320 4matic
My 06 e500 4matic has the code p0400 witch is the exhaust gas recirculation flow, autozone said fuel injection cleaner sould fix the problem so i bought a techron one,but before i put it in i like to ask you guys, you think it will fix this or you recommend something else?
Thank you, George
Old Mar 25, 2020 | 06:31 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Thank you, George
Nope, it won't! Check the vacuum lines , and the EGR hoses too! The EGR line may be clogged up, and/or the EGR is stuck in the closed position. I would replace it! The parts are obtainable on fleabay and takes about 1 1/2 hours of sweat equity!
R
2MERKS
Old Mar 25, 2020 | 07:36 PM
R
2MERKS
thank you, i will check them 👍
Old Mar 25, 2020 | 08:31 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
No worries, but pretty sure the crew(member) will chime in! The group has talent!
