E-Class (W211) 2003-2009
another airmatic question/issue
Old Mar 31, 2020 | 04:54 AM
Matteo Sukic's Avatar
w211 04 e220
Unhappy another airmatic question/issue
I have noticed that my front 2 shocks lower always about 0.5mm over night,both at the same time,while rear ones don't move inch.I left the car for 3 days 1 night it lowers 0.5,other 2 it doesn't move.So I'm thinking could it be that the only sensors are failing?
Old Apr 4, 2020 | 04:39 AM
w211 04 e220
anyone? i did a 24 hr measure front ones lowered around 0.8mm same on both sides, rear ones didn't move
Old Apr 4, 2020 | 10:33 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Could be as simple as ambient temperature change affecting internal air spring pressure. The numbers you mention are down in the noise. When you start talking 20-40mm in a night then you have problems.
Old Apr 4, 2020 | 11:36 AM
w211 04 e220
Could be it is only happening as i mentioned first night other days it doesn't move a bit..
Old Apr 5, 2020 | 11:18 PM
rodneypierce's Avatar
2009 e550 4Matic
Mine will drop or raise that with the ambient air temp differences between night and day (as bbirdwell said above) Nothing to worry about IMO. Once it starts dropping more as stated, then you have an issue.
Old Apr 6, 2020 | 04:05 AM
w211 04 e220
yes i guess i did once again 48hr test just to be sure first night now around 0.5mm second night 0mm movement over day also 0mm drop
