Airmatic - compressor won't run
Im gonna try my best to describe my problem with my bad english..
I have an 2008 E280 with airmatic, where the strut in front driverside started to leak. Got a new one from arnott and changed this, and the car was ok for 5 days until i got the malfunction with a car and arrow in the cluster, and the car droped down in the next three days.
I thinked it was the compressor that was broken after the leak, and got a new one from arnott today that i installed, but nothing happens.
When i start the car i got the message "please wait, vehicle rising", and after a minute or two, i got the red warning "stop, car too low". The compressor wouldn't start at all, even if i go into star to try something. I can hear all the valves function, and the clicking in the relay.
Now i got an faultcode that says "5508 The pressure line system leak", and if i go into that i got up "B7 Airmatic pressure sensor" that says 6,31 bar.
Is there someone who had the same trouble? Is it the valveblock? Or could it more likely be a broken wire?
STAR states specifically for that 5508 code:
-Do not replace control module N51 (the one under the passenger floorboard)
-Check intake system of air system of compressor for clogging
-Pneumatic test of component A9/1 (compressor) ; (if it won't start, see above)
-Check for leaks (Advanced search for user Konigstiger and airmatic leaks will provide you the MB documents to search for leaks)
I tried the pneumatic test, but the compressor won't starg at all. Tried this on the old compressor before i swapped, but the same happened.
