E-Class (W211) 2003-2009
Headlight harness
Old Apr 14, 2020 | 04:48 PM
W211BT's Avatar
2007 Mercedes E320 bluetec
Headlight harness
I have 2007 e320 and I changed my bulbs to LEDs and my light would turn on then off. I plugged in the old halogen bulbs and it would do the same thing. Could this be cause of a short? If so how can I change or try and fix the harness without having to take my headlamp off. Or will I have to take my headlamp off? The passenger side is fine, there’s no wires showing like this side.
Old Apr 15, 2020 | 09:53 AM
pppcguy's Avatar
w211e200komestate
The insulator is gone and the wire makes contact to each other and causes the mulfunction. You may have to remove the headlight/open the lens cover/shield the wire.
Old Apr 15, 2020 | 10:05 AM
W211BT's Avatar
That’s what I was trying to avoid... ughh. Is this the right wire harness for my model?
Part #: 2108200013
