E-Class (W211) 2003-2009
Is the Keyless Go module gone?
Old Apr 30, 2020 | 01:27 PM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
Hello,
After 6 weeks (work from home) of almost no movement combined with almost every day rain, I found that the the Keyless Go and the navigation don’t work anymore. Yesterday, checking the trunk I found the paneling to be completely soaked and about a gallon of water in the spare wheel well. I am almost sure how it came through, cheap third brake light with bad gasket. My question is about the Keyless Go.
The key transmitters work via RF or IR and the engine starts with the key in ignition but nothing Keyless Go doors or shift start button. I hooked up the DAS and there is no fault code, I tried all of the tests and none of the keys are being picked up by antennas. I am assuming it is a central component since nothing works (I checked the fuse F24). That plus the soaked trunk paneling leads me to the trunk module N102.
Anybody has some experience or how to check the N102 module with (or without) DAS?
Thank you.
