C/S button and manual shifting wont work
Hi
I drive an w211 (2004) .
I have a leaking automatic transmission problem. Detecting the problem, i found that the oil was leaking form the 13 pin electric valve, on the transmission. Unfortunately the valve cannot be removed , cuz the 7mm bolt is stuck in there.(this happens rarely as i searched online. So now i have to change also the conductor plate that holds the valve.( and i haven't find a other way how to remove the stuck valve bolt..?)
what i notice recently is that the c/s button ore gear shift to + - wont work while driving/stoped car, but if stop the car and turn it on again it will start to work, so my question is are those electronic commands related to the leaking 13 pin valve , or the the conductor plate that holds the valve? Thanks
Ps: the oil level in the transmission is ok.
