E-Class (W211) 2003-2009
W211 e63 headbolt failure question!!
Old May 25, 2020 | 12:05 AM
W211GANG's Avatar
E55/E63
So apparently there’s an issue with the e63s with early model m156 engines. My car is at 125k miles already and I’ve never replaced the headbolts with the new ones. Is it safe to say my headbolts aren’t defective? Should I get my headbolts done? I feel like that head bolt issue was blown way out of proportion. Am I safe from this???
Old May 25, 2020 | 11:03 AM
konigstiger's Avatar
'71 Pinto
Have engine oil analyzed at each oil change: https://www.blackstone-labs.com/ if there is any trace of coolant and engine # is within affected range approach MB for goodwill repair citing attached bulletin LI01.30-P-051567.
File Type: pdf
Old May 26, 2020 | 04:18 PM
W211GANG's Avatar
E55/E63
so if my engine # is in that range do I get some sort of discount from Mercedes?
Old May 26, 2020 | 05:48 PM
'71 Pinto
One can argue so if cylinder head bolt is broken.
