Radio Text
-s-
We North Americans should probably be grateful for how advances in consumer electronics are thoroughly field-tested in Europe and Asia before we get them. They say that a stroll through Tokyo's Akihabara District is like a time-travel journey two or three years into the future of the American consumer electronics market. Somehow, I don't feel all that grateful.
If he's in the US, the answer is a lot more complex... but has been covered before.
Some of the things I really like about Akihabara is that after the stores close, you can find a lot of people setting up their own "flea market" tables on the corners, selling off all their "old" stuff ... probably to finance the upgrade to new things. You can pick up a lot of neat things pretty cheap, as long as you're not needing the "latest & greatest".
p.s. I leave my RDS off most of the time because it seems none of the Mercedes OEM radios let you control RDS-text and "best signal" feature separately, and in the SF Bay Area a lot of "best signal" data is transmitted erroneously. So my presets end up taking me to stations that I don't want to hear.
-s-
It doesn't make sense why it isn't inlucded here..
As an example, if I have preset #2 set to 94.6 (fictitious station number), and I press the button to go to station 2, sometimes it will go to 101.8 (again fictitious) because 101.8 is broadcasting bogus RDS info. It seems that many stations owned by the large broadcasting companies are getting "cookie cutter" implementations of RDS, where the installers are "forgetting" to change some of the settings. Apparently this has been an issue for the last year or two as stations have turned on RDS only to turn it off within a few days. Then it has been up and down on various stations over the last couple years. A couple years ago some of the RDS data was so bogus it was causing radios to lock up! It's poor design on the part of the tuner designers that the data could cause a crash, but it also shows poor implementation methodology.
-s-
