Locked out of Car - Completely
Long story short, I was preparing to replace the airmatic compressor. Per the instruction, I disconnected the battery and closed the trunk leaving the keys in the trunk. I am completely locked out (window closed, doors locked) of the car with no spare key. Can someone help me get into my car?
At the least, order the mechanical key which you can use to open the trunk so you can get to the solitary key fob.
A qualified person can pop the door lock using the strap method. A qualified person can use a 12v jump box to apply power at the passenger footwell power distribution block. Then pop the trunk with the switch on the door.
It's probably safer and cheaper to get a new key blade from the dealer like bbirdwell stated.
Worse case is just paying for the metal key at the MB dealer. That will be cheaper than the entire key fob.
