E-Class (W211) 2003-2009
04 E55: Squeaky Brakes
Old Jun 17, 2020 | 06:39 PM
Slider's Avatar
04 E55 AMG
Bad squeak originated from the front brakes.
Installed new Akebono pads and Zimmerman rotors a few months ago.
The sqeak just came back and seems to be originating from the front left.
Any ideas?
Old Jun 17, 2020 | 10:47 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
When you put the new pads on, did you lube everything real good and applied that anti squeal paste on the back of the pads?
Had the same issue on a previously owned 2007 S550 (W221). Took everything apart, cleaned all pins and removed any surface rust, lubed everything real good and applied the anti squeal paste and that did correct the issue.
Old Jun 17, 2020 | 11:36 PM
Slider's Avatar
04 E55 AMG
I took it to a shop and it's possible that they neglected to install them correctly or forgot to add paste.
Have an appointment on Saturday with another place, so hopefully they'll be able to resolve the situation.
Old Jun 17, 2020 | 11:38 PM
S70Houston's Avatar
Good luck, ....... Keep us posted.
