E-Class (W211) 2003-2009
Minor Dent Removal
Old Aug 11, 2004 | 02:04 PM
CALBenzo's Avatar
'18 E63S AMG
Minor Dent Removal
I recently incurred a minor ding at the body line of the passenger door from some inconsiderate soul. I'm still not sure where I received it since I'm pretty careful where I park. Thanks in part to the nanopaint, I suppose, the paint was not chipped.
Anyway, many could probably live with it, but it bugged the crap out of me.
I called Dent Pro here in the Bay Area, and they did a great job. I was worried since it was at a body line, but they said they could get it out. Cost about $90, but worth it to me. Pretty impressive.
Attached Thumbnails Minor Dent Removal-dent1.jpg   Minor Dent Removal-dent2.jpg
Old Aug 11, 2004 | 02:17 PM
konigstiger's Avatar
'71 Pinto
The thought of this happening always scares the hell out of me. Glad to “see” that they did an excellent job. Curious though, did you observe the repair and if so, what method was used?
Old Aug 11, 2004 | 02:44 PM
CALBenzo's Avatar
'18 E63S AMG
The technique was much different than I anticipated. I had always imagined that somehow they use suction of something. Now when I think about it, that would be too difficult to apply at a body line, and might even dislodge the clearcoat on older paint.
Anyway, he didn't have to remove the interior panels in this case, although he said they do it in some cases. Here, with the window rolled down, he slid a protective sheet between the window and the outer door panel. He then used some tools to push out the dent from the inside. Then he pushed it back in from the outside (using a rubber ended punch rod and a hammer), repeating this process until it was flat.
He mentioned that mercedes, and other higher end vehicles, were easier to work on since the alloy of the panels were better, and paints and clearcoats applied were more flexible.
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
I've used PDR ("paintless dent removal") in the past and can also attest to the good results; you would think that a small dent would stretch the metal and make total removal impossible, but a good PDR person can make a small dent literally disappear. They use rods and other specialized tools to manipulate the metal back into shape from behind. If the dent is reasonably close to a window they can reach it via the weatherstripping. A dent that can't be reached from behind without major disassembly would be a problem for them.
Old Aug 11, 2004 | 03:28 PM
jyg e500 maybe's Avatar
2000 528BMW 5sp
well worth it
my got got numerous dents from hail storm, If tech can get behind dent he can make it dissappear.
Old Aug 11, 2004 | 03:49 PM
DWP's Avatar
DWP
If the hailstorm was recent, look for PDR ads in your local paper. I've heard that some PDR techs are itinerant and the follow hailstorm reports. If I found one that way I would avoid paying in advance for the work, though.
Old Aug 11, 2004 | 04:00 PM
johna1's Avatar
17 E220D, 11 E350 CDI(sold), 06 CLS320 CDI (sold), 05 Cadillac DeVille (gone), 04 E320 CDI (sold)
I got a dent right by the fuel filler, which is a totally inaccessible area. they removed it with suction which worked perfectly. The paint had been undamaged. They said the dent was from the back door of an SUV, which made a small impression just above waist height.
I am also careful where I park, my partner complains about how far we have to walk, but someone will always get you!
Old Aug 11, 2004 | 04:06 PM
'71 Pinto
CAKBenzo, DWP
Interesting, thanks.
Old Aug 11, 2004 | 04:43 PM
benzboy's Avatar
SL500 E320 ML350
That's a nice job. I've had similar work done on several MBs in the past at Dent Magician (our name for the franchise here in the Northeast). Costs much less than traditional body work and no paint matching nightmares!!
Old Aug 11, 2004 | 10:20 PM
mbfan67's Avatar
pinto
Wasup Cal, hey the funny i got the same dent on my driver side door!! bug the hell out of me!! i think it's the area that we live in bro. people dis-like people that drive benz. i got the dent the first week i got the car, but mine is a bit worse than your's paint chip off. shop wanted about 500 to fix. haven't got to dent pro yet since they don't do touch up but i'll call them this weekend to get the dent out. nice job on the car BTW.
Old Aug 12, 2004 | 01:02 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
I had a dent in the rear passenger side door on the crease too. I also watched the fellow massage the dent out with the tools described above. The results are fantastic.
I had similar dents in a C280 that were removed so I purchased 4 year dent removal insurance for $300 when I bought the E320. I figured that even if I didn't need to use the insurance, it would be like carrying an umbrella to prevent rain. The fellow came to my house to remove the dent and removed the bad dent and another small dent in the front passenger door. He said that he would have charged me $149 each for the dents so I figure that the insurance has paid for itself and I still have 3 more years of coverage.
Jim
