What ACTUALLY Happens When SBC Fails?
and furthermore, I don’t have to disable the SBC while changing out pads or rotors.
Of course, that’s done so that a failure doesn’t cause a fall from the sky with the associated undesirable consequences. Most failures in an automobile either cause a failure to depart or a roll to a stop. Except for the brakes. When you need them, a failure often results in an accident.
The SBC system, as sophisticated as it was, didn’t give the driver any indication of an impending failure. It didn’t even give an indication of where the system was in terms of a predetermined usage limit. There was no warning that you had used up 90% of your allowable pedal pushes and should schedule some much need maintenance.
Personally, I am glad it’s gone.
It's easy enough to pull codes from the SBC unit. The warranty codes are clearly defined. It even covers the wheel speed sensors.
For anyone still curious about how the brakes work after an SBC failure, find a large empty road or parking lot, pop it in neutral with the engine running, put on the parking brake and unplug the SBC as shown in the video. Now drive it. You won't be able to go very fast but you will be able to stop the car without a problem. Turn off the engine, plug it back in and SBC is back to normal. It ain't rocket science.
PS I haven't gotten an analyzer yet that shows the number of SBC actuations so I'm completely in the dark about that.
For a basic scanner which everyone should have in their toolbox, get the Autel AP200, around $50. If you want something more complex, consider the Launch X431 Creader Elite 2.0 Benz, it can do a little programming too but not sure if it can read the number of brake presses.
R.K.
R.K.
R.K.
R.K.
Also, my indie mechanic texted me and it looks like it might be a SAM issue or a wiring. He scanned it and there was a power loss on wire 87. I hope its just a bad wire...
R.K.
R.K.
R.K.
Same over here, I was doing 60-70mph on the highway when mine failed. Unfortunately not crowded, so I was able to put it on the side of the road safely with 5-10% braking power
No thanks. I'll keep this one and fix it.
R.K.
