E-Class (W211) 2003-2009
W211 HID headlight problem
Old Aug 14, 2020 | 02:42 AM
Charltin's Avatar
2004 Mercedes E500 4matic
HID active-cornering low beam problem(2004):
I had both low beams go out on my car so I changed the bulbs and ballast-all was well for a month or so. Now my right low beam went out so I tried a new igniter but still nothing, Any ideas on what I should do next??
(Left low beam still works fine)
Old Aug 14, 2020 | 03:11 PM
cetialpha5's Avatar
Swap the bulbs from one side to the other to see if it's the bulb or ballast. Also cheap eBay bulbs are usually fake and will flicker or die quickly after installing. Real HID bulbs from Osram or Sylvania will be in the $50-$100 range and may even have a QR code to verify authenticity..
Old Aug 14, 2020 | 03:13 PM
Charltin's Avatar
I will try to do that when I get some free time, I got my ballast and bulbs from Headlightexpress. I am under the impression that they are higher quality than eBay parts
Old Aug 14, 2020 | 03:28 PM
cetialpha5's Avatar
Are those factory or aftermarket lights? Factory bulbs are usually more expensive. That vendor says that they have a lifetime warranty, I suggest you contact them. They're not using name brand bulbs like Osram, Sylvania or Philips. They may be a step up from eBay but they're not name brand bulbs.
