E-Class (W211) 2003-2009
Loose Engine Cover Insulation
Old Sep 7, 2020 | 03:20 PM
ptkacik's Avatar
2005 E320 CDI, 2015 GLA 250
Does anybody have a solution for reattaching loose engine cover insulation?
This felt blanket thing looks like it might have been heat welded or maybe ultrasonic welded to the underside of my engine cover. Over the years it has just started pulling away. I would like to reattach it but think that double sticky foam tape or glue might not handle the temps on my 2005 E320 CDI engine cover.
Thanks,
Peter
Old Sep 7, 2020 | 04:02 PM
konigstiger's Avatar
'71 Pinto
Old Sep 7, 2020 | 04:22 PM
ptkacik's Avatar
Sorry. Not the hood liner, the liner under the plastic engine cover. Every time I pull the plastic engine cover off, it seems to tear away a little bit more. Now at 15 years old, I have to hold everything together while I replace the cover. Sometimes stuffing it back up in there.
Peter
Old Sep 7, 2020 | 05:00 PM
'71 Pinto
My mistake.
Old Sep 7, 2020 | 06:16 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Clean both the engine cover and the foam really well, spray with aerosol 3M contact cement on both surfaces, reapply. Been working for my cover insulation for a couple years now.
