E-Class (W211) 2003-2009
Stardiagnose
Old Aug 18, 2004 | 04:36 PM
ajm0824's Avatar
2005 E320
Stardiagnose
Is it possible to get a copy of the service software that the technitions use?
A frend of mine purchased software for his audi and loaded it on his laptop. Now he can do all sorts of things with it.
Am I correct to assume the one for W211 is StarDiagnose?
Does anyone have more info about this? Even some background info on how it works?
Old Aug 18, 2004 | 04:50 PM
awiner's Avatar
2003 CL55 AMG
The software is easy to get. It's the MUX (Multiplexer) that the cables need to run through that is expensive to buy (~$4000.00). Without the MUX, the software won't even install or do much good.
Old Aug 18, 2004 | 07:30 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I think you can get the software to install by bypassing the Autoplay feature, or replacing the separate program that determines if the machine is an "official" DAS machine.
I guess since this is technically a hack, you're still correct.
-s-
Old Aug 18, 2004 | 08:00 PM
ajm0824's Avatar
2005 E320
Does anyone know where one can get the software?
Old Aug 18, 2004 | 08:24 PM
scorchie's Avatar
You might be able to order it from the dealership. It's just a media charge because I think it doesn't work if there's no license key, and if the hardware for the Star Diagnosis isn't there, it doesn't do much anyhow. I just said you could install it. Adam said that it would be useless, and he was pretty much spot on.
p.s. I am pretty sure the hardware is "Star Diagnosis" and the software is "DAS".
-s-
