I recently fixed my sunroof from the motor not engaging properly and I believed when I reinstalled the overhead console I damaged the wiring for the interior temperature sensor. The only reason I noticed it is because my heated steering wheel would turn off after 15 seconds. When I plugged in my diagnostic reader is said that my there was a voltage issue with the temp sensor in the overhead console. I did a live test and it reads a constant 147 degrees. I took down the console and noticed there is are two wire in one terminal (white and brown) it connects to the blue connector circled in the pics. I'm missing the end of the plug somewhere. I can't find anywhere online that shows what each of the connector inputs are for. Does anyone know if these are in fact the wires for the temp sensor? If so, I'm going to need a new (used) pigtail for it to replace it because this is 2 wires that seem to connect into an l shaped receiver with about 5 or 6 pins. Thanks in advance for any help.
