P2633, Need Help!
While diagnosing the issue, I discovered and fixed the following:
- Turbo intercooler hose had a crack / leak, replaced both hoses and pressure tested the turbo side of the system to 20 psi.
- PCV valve diaphragm was torn, replaced the assembly.
- Air filters were filthy, replaced them both.
- Replaced the turbo electronic actuator, don't know if it was bad or not.
- Replace air intake tube and MAF sensors, don't know if this was a problem or not.
- Replace the gasket between the PCV and the air intake.
- Tested the intake flapper motor, works fine.
- Tested the MAF sensors, work fine.
- Tested the turbo actuator, works fine.
- Tested the EGR actuation, works fine.
- "Quantity Mean Value Adaptation data".
- "Air Filter Learned Values".
- "Lambda Values."
At this point, the CEL persists with P2633 and the P2011 fault codes. I have run out of options to diagnose and investigate.
Does anyone have any suggestions? Many thanks from a desperate E320 owner.
