E-Class (W211) 2003-2009
Need to know if a E350 06 has the suspect engines for balancer shaft
Old 10-31-2020, 11:53 PM
Adelcamp's Avatar
C250 2012
Howdy, my name is Agustin, I am buying an old MB 2006 E350 with 81,000 miles, VIN WDBUF56J06A833294 according to Russian site it has engine Engine 272964 30 106728, I Need help to identify if the car I am buying has the potential for the shaft balancer failure, , any help is greatly appreciated it.
Thanks!
Old 11-01-2020, 01:17 AM
cetialpha5's Avatar
Received 1,506 Likes on 1,177 Posts
It's a simple answer. ALL 2006 models have the balance shaft problem. Some early 2007 models also have it.
Old 11-01-2020, 10:24 AM
konigstiger's Avatar
Received 4,448 Likes on 3,155 Posts
'71 Pinto
As suggested engine is in affected range, clear point (not affected) as of 2729xx30 468993.
Old 11-02-2020, 08:36 AM
Adelcamp's Avatar
C250 2012
Old 08-13-2023, 11:26 PM
scotty68's Avatar
E320 CDI
this vin effected?
WDBUF56J46A849594
Old 08-14-2023, 03:48 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
It is the ENGINE Number that identifies those with the balance shaft issues, NOT the VIN. This is because that engine appeared accross the whole MB range/ See the attached bulletin from MB that specifies the engine number ranges for those engines that are impacted.
Old 08-17-2023, 07:56 PM
TexasMule's Avatar
2009 E350
Originally Posted by scotty68
this vin effected?
WDBUF56J46A849594
Yes, this VIN's engine number is 30 132919, well before the cutoff.
Quick Reply: Need to know if a E350 06 has the suspect engines for balancer shaft
