E-Class (W211) 2003-2009
Lowering the REAR
Old Nov 3, 2020 | 01:55 PM
MyrtleBenz's Avatar
e500
Lowering the REAR
I have read a bunch of things on here and vendor instructions. I have installed links up front and got a nice drop and i removed the 2 nuts to the bracket for the rear sensor and put washers under the bracket. STILL doesnt seem to do anything to lower the rear.
Will loosening the u bolt and adjusting the top bracket get me the drop im looking for???
Old Nov 4, 2020 | 02:44 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
https://cimg1.ibsrv.net/gimg/www.mbw...b7ae3a2ba2.jpg
It is suppose to be like this.
Old Nov 4, 2020 | 03:36 PM
MyrtleBenz's Avatar
e500
yes. thats what i did. doesnt seem to have much of an effect on lowering the rear
Old Nov 4, 2020 | 03:52 PM
fkong777's Avatar
you can either add more washers or I actually used composite construction shim and wedged it in between the bracket and subfloor. However that stud is short so make sure you can get a couple turn in to tighten the nut.
