E200 Kompressor Not Starting after sudden engine cut off
W211 E200 Compressor 2005
Hi guys .. I'm from Tripoli , Libya
I own a ( March - 2006 ) E200 Kompressor which was running perfectly and had no issues at all and in a very good condition.
History : Crankshaft sensor replaced
: SBC system replaced
Two months ago I took it to a repair shop who has original Mercedes computer reader for a regular service to check for codes or problems to do service in advance but everything was ok no codes no problems.
Few days ago I started up the engine in the morning and it started normally , nothing strange or unusual , after exactly one minute while I was touching the climate control different buttons to adjust it, the engine died suddenly and will not start again since. The engine cranks but no start. I checked evey fuse and relay in all three fuse boxes.. nothing.
I bought OBD II reader and checked the engine for error codes .. I found inactive codes archived about intake manifold but no present codes. No errors on car dashboard screen. Everything is working in the car. Fuel Pump makes operating sound when I turn the key to position 2 .. but when I start .. it cranks for seconds but will not start.
I have nothing left to try .. any suggestions ?
The car has now 180,000 KMs
Libyan Droid (11-23-2020)
