E-Class (W211) 2003-2009
Transfer Case Noise E350 4matic
Old Dec 7, 2020 | 02:00 PM
Dragon888's Avatar
2007 E350 4matic
Hi fellow Mercedes Benz enthusiasts!
I have a 2007 E350 4matic that is making a very noticeable "knocking" "ticking" noise that only occurs when accelerating. It "knocks" faster in pace the harder you accelerate.
In an attempt to find where the sound is coming from, I had the car up on a lift and listened for the sound as someone was stepping on the gas (again, it only makes the noise when accelerating). With a Stethoscope, I was able to pinpoint the sound coming from transfer case.
Replacing the transfer case for my car is a very expensive repair and aside from the noise, the car is running perfectly fine. It would be great if there was anything else I could do to remedy this issue. (Transfer case fluid change, replace bearing)
Has anyone here ever experienced this or does anyone know what this "clicking" "tapping" noise may be? I am thankful for any insight on this matter.
Old Dec 7, 2020 | 04:01 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
Did you check the fluid level while you had it lifted up?
Old Dec 8, 2020 | 08:47 AM
Dragon888's Avatar
2007 E350 4matic
UPDATE
I had a Benz technician perform a transmission service (fluid, filter, gasket). He also changed the transfer case fluid. The "knocking" "ticking" noise in the transfer case is now significantly less and not noticeable like before. I am satisfied with the improvement.
Transfer case service $200
Transmission Service $340
Old Dec 8, 2020 | 10:07 AM
konigstiger's Avatar
'71 Pinto
If noise should return here is MB procedure to rectify hold on to attachments for future reference to avoid TC replacement.
File Type: pdf
File Type: pdf
Old Jan 20, 2022 | 01:27 AM
nika_kirkitadze's Avatar
E350 4matic
Hello, could you please share the source where you found this useful .pdf files? I am looking for the same for E350 4matic. thanks in advance
