EVB ABS ESP virginise
All the assosiated lights are on. I originally caused this problem by terminating "test drive" intiated from DAS. I have now fixed this. In the course of troubleshooting I created another problem. Using DTS Monaco i think i overwrote. "PDU" setting..I am a fool.
my vin is WDBUF56X39B376564. I cannot locate the ESP module, i do not see anything near the driverside headlight or between headlight and the fuse box. Can someone please tell me were it is? And when found is the a way to reset it to a blank virgin canvas, and remarrry to car.
P.S the error i see in xentry is 4841 control unit N47 (ESP control unit) does not match the vehicle, abd DTS Monaco cannot communicate with it.
thank you
thank you
Sorry I did not see your post sooner. I resolved the issue some time ago. There was actually a defect in the ABS module. A gentleman from this forum 'Benz Ninja' remoted into my pc saw the issue in the ABS module. I replaces ABS module, put the old ESP module back (attached to the ABS module), and the car runs well
