E-Class (W211) 2003-2009
Error code p2015
Old Jan 22, 2021 | 02:31 AM
W211BT's Avatar
2007 Mercedes E320 bluetec
Error code p2015
I have a 2007 e320 bluetec. My check engine light came on with the code p2015 and now my car seems like it lost power or boost. After I take off it seems find until it shifts into the next gear then it slowly creeps up on speed. I can go up to 70 mph still but it take like 20 seconds to get there. What could be causing this problem and what could I do to fix it..
Old Jan 22, 2021 | 09:13 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Intake manifold swirl flap motor is the first thing that comes to mind. My car threw that code when the motor quit working, symptoms just like yours. Not a difficult fix on the straight 6 but can't attest to how easy it is on the bluetec.
Here's my thread on it:
https://mbworld.org/forums/e-class-w...here-hell.html
Old Jan 24, 2021 | 01:14 AM
W211BT's Avatar
Thank you for your response! I thought it was my swirl flap motor. I already know it’s an expensive fix. But what are your thoughts on a swirl flap delete? Is it a good idea or should I just get it fixed.. what should I look out for?
Old Jan 25, 2021 | 09:37 AM
2013 ML350 Bluetec
$150 for the part plus a few hours if you're going slowly makes it one of the cheaper fixes on a Benz, even if you hire it out.... As long as the flaps themselves are able to move freely, why not fix it correctly?
Old Jan 25, 2021 | 11:08 AM
W211BT's Avatar
I would like to fix it properly, I just expected it to cost like $1,000+ to get it fixed and would not like to spend so much.. how much would you expect it to cost...?
