E-Class (W211) 2003-2009
airmatic question
Old Jan 24, 2021 | 05:49 AM
Matteo Sukic's Avatar
w211 04 e220
Exclamation airmatic question
In a recent few days it got very cold from around 10c to -15c after a few days of sitting rear right side of the car was on the ground, but the front was risen all the way up,how is that possible? I know that it wasn't even close that high to that when I parked it..Now it is a bit warmer and the car stays level normally..
Old Jan 24, 2021 | 09:49 AM
konigstiger's Avatar
'71 Pinto
Could be bellows are failing visually inspect all four, but before replacing consider compressor rebuild with new desiccant to rid system of moisture given temperature related: https://www.benzworld.org/threads/ai...ccant.2411265/
Old Jan 24, 2021 | 10:09 AM
w211 04 e220
when i unlocked the car the front lowered to its normal position but rear pumped in about 5 secs and i didnt even hear compressor running nothing it just pumped how is it pumping without turning on car ? I am getting more and more confused
Old Jan 28, 2021 | 05:26 AM
MG7788's Avatar
Mercedes E320 4 Matic, Audi S3
Mine E320 also does that. I think that its common during winter times.
Old Jan 28, 2021 | 05:17 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Your car has a pneumatic reservoir.
Go here, download attachment, read and learn.
https://mbworld.org/forums/e-class-w...ml#post7932108
Old Jan 28, 2021 | 06:13 PM
Mike horstman's Avatar
2010 E550 sport
I don’t know what you have, but I have a 2010 e550. When I first bought it the very next day the front passenger side was dropped. Each air strut is independent. You also have stabilizers that try to level the car. When I would start it up I’d get a warning the vehicle was to low. Then the compressor would lift it back up. And I was good to go. The used dealership I got it from tried to tell me this was normal with an older car. I wasn’t buying his BS. I found the best deal for these struts at rock auto. I decided to replace both front struts as I could see the plastic covers were shot on both. Luckily for me the dealership had left a letter addressed to the previous owner. He informed me he had just replaced the rears. I got each Arnott strut for about $530 which was a surprise as everyone I talked to said about $1200. When they came they looked much different than what I removed. Rock auto has 0 customer service. So I contacted Arnott and found out 2 things. 1 they were just redesigned for better longevity and 2 they will take the old ones back. Mine had a core of $115 each. The job was easy, it was the tools that became the problem. As you need E sockets. Then as o got through the job found out I needed an e wrench for one bolt. The only place to get the wrench was online. Had I listened to the used car guy I would have burnt up my compressor pretty fast. I hope this was helpful.
Old Jan 31, 2021 | 12:28 PM
NorsemanE320's Avatar
MB E320CDI
have had mine E320cdi since 2008. I experience the something similar every year, i get a airmatic errormessage, visit workshop. When the weather gets warmer, the message disappear. Think it could be something due to the volume of compressed cold air, but not sure.
