retrofit memory seats, possible?
I have a w211 win nr:WDB2112081B281033
got a parts car, with memory seats, and i dont have memory seats in my car, is it much work to retrofit it, do i need to change some wireing?
i know i need to change the door panels, the thing is that in my old seats the srs sensor is broken, and the memory seats are in perfect order, so it would be really cool, if it was possible to swap the seats
Hope someone can help me with a answer here
Regards from:Lars
Regards from:Lars
I suspect wiring will need to be changed around the motor, and the motor itself may need to be changed out as well.
Get in touch with Steve or Wanda from MBenzNL and they'll be able to point you in the right direction in terms of what will need to be done. I haven't seen this done on this forum at least for the W211. Good luck.
https://www.facebook.com/MBenzNL/
