E-Class (W211) 2003-2009
Bizarre Window Issue
Old Feb 27, 2021 | 12:59 PM
rishih's Avatar
CL63 AMG and E220 CDI
hi all the car is a UK, RHD E220 CDi, W211 2006
The car needed a new battery in the trunk/boot, after changing the windows have some bizarre behaviour.
Nearside front (passenger) window works fine with the switch on its own door. Nearside rear doesnt work at all using switch on the door or the master switch next to driver. Rear offside, drivers side, doesnt work either with any switch too. The switches on passenger, and both rear doors you can see the orange LED illumination on the switch. On the driver door the illumination on the switches are not present, none of the switches work even on the passenger door which is the only window that works using its own switch.
Fuses are fine, electric mirrors, electric seats and all other electrics are fine. OBD scan showing no faults.
Im wondering if the drivers side switch is faulty, and if it was would this cause this behaviour? Can anyone help me...or give opinions of what i should check next thank you.
HELP!! x
Old Feb 27, 2021 | 03:08 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
A generic OBD scanner won't tell you anything but engine emissions issues. There's a plethora of other info the car is trying to tell you that can be accessed with, for example, an icarsoft MBii scan tool.
Personally, if I didn't have one of those, I'd disconnect the battery for 10 minutes then reconnect (+) first, (-) second. Go from there.
BUT: a good scan tool will allow you to view the actual states of the switches in question, as well as engage the window regulators without using the switches at all. Sure makes troubleshooting easier.
Old Feb 27, 2021 | 04:38 PM
rishih's Avatar
Hello
Thanks for your reply, I did disconnect the battery for around 5 mins and reconnected and it was the same. Shall i retry for 10 mins?
Sorry i should have said, I actually have the icarsoft scanner is what i used, i couldnt see any faults on there at all. i wasnt aware this tool could do more than just scan?
Can you recommend next steps with the icarsoft? or other things to try?
Old Feb 28, 2021 | 10:13 AM
csargent001's Avatar
'18 C43, '10 X5, '08 G35x
If you recently replaced the battery, chances are you just need to re-sync the windows and sunroof. I had to do this in my '08 E550. The manual for the car will tell you how to do this. A Google search should also produce some DIY videos. This is a simple process, I just don't remember what it was. Good luck!
Old Mar 2, 2021 | 12:53 PM
rishih's Avatar
Thanks but it definitely isnt a resync issue - the passsenger front window works fine using the switch on the passenger door, using any other controls it does not work and no other windows work either...
Old Mar 2, 2021 | 02:19 PM
konigstiger's Avatar
'71 Pinto
Sounds like driver door control module needs to reset. Pull f21, 22, 32, and 33 @ interior fuse panel) for 10 minutes in an attempt to reset all DCMs. If this fails turn everything off (radio, etc.), disconnect battery ground line, reconnect after a waiting 15-30 minutes (CAN should change to sleep mode) modules should reset.
