E-Class (W211) 2003-2009
Damaged steering column shaft
Old Mar 14, 2021 | 07:52 AM
sjcb's Avatar
2003 CLK500 CABRIOLET + 2003 W211 E500 sedan
Have been working on restoring 2003 e500 interior back to original color.
steering wheel has not been right since I purchased it. So left it till last ...
issues
- indicator cancelling switch broken
- srs code on (clock spring)
- motorised adjustment not working (fuses etc checked)
so decided to investigate and pulled the steering wheel off and WOW ... found the steering wheel shaft damaged ??? I am trying to understand what has happened here???
can anyone tell me if the damaged piece can be replaced only or do I need to replace the whole column ?
thanks in advance
Old Mar 14, 2021 | 11:06 AM
konigstiger's Avatar
'71 Pinto
Jacket tube needs replacement (part # 2114601616) search ebay used, see attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 18, 2021 | 09:28 PM
sjcb's Avatar
Thank you @konigstiger
