CEL for Evap under G-force load
I can clear the code but it comes back after a few hundred miles. Now I'm noticing that it's only every few hundred miles between throwing a code because that's how often I have the opportunity to do a full out 0-70 blast or pitch it into a high speed sweeper. It's the G-forces that are triggering the Evap CEL. I just did it last night on a 120 degree sweeper. Also seems to happen with a partial tank of fuel (could be unrelated).
Prior to coming to this G-force realization I have swapped out:
- the fuel shut off valve (Y58/4), which is what the P2422 code point to;
- the charcoal canister;
- the purge control valve (Y58/1); and
- the gas cap.
Question: could an errant fuel tank pressure sensor trigger a CEL under G-forces? And, is it possible it would show as a P2422 code?
I can trigger a CEL with a hard right turn almost on command.
Fuel slosh?
Wiring?
I was hoping this was a somewhat common problem that a MB mech may have dealt with in the past. Not excited tracing all the vacuum and electrical lines looking for a fault. I still think it's related to fuel slosh - I did change the pump and filter myself 3+ years ago and maybe one of the 3+/- lines that cross between tank sides came loose. Only about an hour or two to open up the tank.
