w211 e350 wont start
The OBD scanner shows the following..
Confirmed Diagnostic Trouble Codes
-P0071: Ambient Air Temperature Sensor Circuit "A" Range/Performance (Powertrain, Generic)
-P0073: Ambient Air Temperature Sensor Circuit "A" High (Powertrain, Generic)
-P2004: Intake Manifold Runner Control Stuck Open Bank 1 (Powertrain, Generic)
-P2004: Not available in trial (Powertrain, Mercedes-Benz)
Pending Diagnostic Trouble Codes
-P0335: Crankshaft Position Sensor "A" Circuit (Powertrain, Generic)
Your intake manifold problem wouldn't account for it not starting, usually that just makes the car run rough. You should replace the oil separator and the oil breather cover, that caused the intake manifold runners to get gummed up with oil and now the flaps don't move that easily. You would normally replace the intake manifold to really clear the code but that's a project, It's about $650 on FCPeuro but they do 5% off once in a while if you leave it in your cart and don't check out.
Any ideas..anyone ?
