Oil leak after changing oil cooler seals- residual? 2007 e320 bluetec
The wierd thing is I see a cloth/sponge like cover closer to the front of the car next to the oil pan and it was saturated with oil before I changed the oil cooler seals. what is that cover? Can it be removed? And how do I clean that? I sprayed some degreaser on it and cleaned some out. I went to touch it again and it is still oily. Looks like it is the possible culprit. I am assuming it’s that cover that’s causing the leaks? My thoughts are that it drips down on the rack and pinion and oil line so it looks like those are leaking. But like I said, I decreased it today. I tried looking in the valley and didn’t see any shiny areas of oil... looked dry to me. Check the area for turbo seals, looks clear.
It took me 36 hours to change those POS seals and I torqued everything to spec. Runs much smoother and cleared up a hesitating issue I had on the car at light throttle. Picks up pretty good too! The major time consumption was cleaning out the intake manifolds and what not.
I’ve got a catch can on the way to avoid oil from getting in the turbo inlet.
any thoughts?
thanks in advance!
