ATM oil+cable gland change, now doesn't start
I had a less than tight screw on my ATM case so some oil was leaking. Today finally instead of adding fluid I decided to fix it. I drove the car and bought parts, back home and jacked it up. Took the oil pan off, and while at it, also replaced the cable harness adapter thing. I did not disconnect battery while doing any of this.
Then I put everything back together, add ATM fluid, try to run the car ...and it's dead. Doesn't start. Key goes all the way, no turning, no click (I'm not 100% sure about no click)
Now that I think about it has done the same (not starting) few times in the past, turn key, nothing happens. Turning it back and forth again has always worked.
Details:
Details:
- Battery 12.6 VDC
- All engine bay fuses are OK
- Start relay is OK (and probably the sound I hear when turning key to ignition)
- Can change gears and they display on instrument panel
- Does say service D exceeded by 11000 km
- 9102: Coding of control module ASSYST PLUS is fault [Airbag?]
- 9126: Fault in CAN to Audio
- 9116: Fault in CAN winth control unit N72/1 (Upper control unit)
- 9070: Component K75 (Cutoff relay for interruptible loads) or the signal wire to component is faulty
- 930E: Synchronization of DTC memory cannot be ensured
- 9032: Component S88/8 is stuck or has short circuit
- 9096: Control unit N72/1 (Upper control panel unit) is not transmitting data on the CAN bus
- 9027: Component M16/32 (Heat exchanger shutoff motor) is faulty or the leads has open circuit
- 9096: Fault in CAN with UCP
- 9040: Component N10/1kO (FAN relay module) is defective or not installed
- 9026: Component M16/32 (Heat exchanger shutoff motor) is faulty or the leads has open circuit
- 9028: Fault in CAN comms to unit N93/1 (Audio)
- 6230: Electronic Stability program control
- 6210: ABS anti locking braking system
- C249E: Undervoltage supply
- C2258: ABS control
