E-Class (W211) 2003-2009
Engine Vibration Still Continues
Old Jun 22, 2021 | 11:17 PM
joe5000's Avatar
E320 4Matic
Post Engine Vibration Still Continues
Hey guys so i have been having this problem for quite some time now my car has only 89000km. I changed the engine mounts, the transmission mount, spark plugs, pulley, tensioner and lastly the harmonic balancer even after changing all these pieces, the engine vibration continues when I leave the car on P or N. by going in reverse or drive i barley feel anything,
when I'm driving i don't feel any vibration smooth as a whistle. (PS there is a difference of before changing all these parts compared to now)
the only thing i don't quite get is even after replacing my harmonic balancer there is a tiny vibration to it, maybe you guys can shed some light on this my mechanic seems to say that its ok and its not the problem and that the harmonic balancer is fine.
I've been doing some research online and seen a few video's talking about the front drive shaft being one issue, I'm starting to think this might be it since the vibration is coming from under the seat, also when looking at the engine you can see there is a slight vibration like there is a misfire going on but i didn't get any codes i tried disconnecting each coil to see if one was faulty they seem to be in good condition.
also forgot to mention if it may help when turning on the air conditioning or heating in the car you can feel the vibration even more, as-well as when i put the car in Sport mode.
please anyone with some insight on this issue would be of great help its becoming annoying i just want it fixed.
Old Jun 23, 2021 | 12:54 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
What brand mounts did you install? It seems to make a difference.
Old Jun 23, 2021 | 09:26 AM
F1Fan's Avatar
What year, what engine is this?
Is it even possible for the front driveshaft to vibrate when the car is in Park?
Old Jun 23, 2021 | 06:09 PM
joe5000's Avatar
E320 4Matic
i dont know but the vibration is coming from under the seat so im guessing it would be that.
here is my engine
02 C320 wagon
04 E320 wagon/Sedan
87 300D 5spd
Old Jun 23, 2021 | 06:11 PM
joe5000's Avatar
E320 4Matic
i used BOGE mounts never had an issue with them in the past. but i don't think its the mounts the problem
Old Jun 23, 2021 | 06:12 PM
joe5000's Avatar
E320 4Matic
forgot to mention its an E320 4matic 2004
Old Jun 23, 2021 | 09:16 PM
F1Fan's Avatar
So this is the 3.2L v6 M112 engine connected to the 5 speed 722.6 transmission?
Let's look at all the rotating parts at the front of the engine.
Harmonic Balancer. Replaced.
Tensioner. Replaced.
Pulley, Idler Pulley. Replaced.
Power Steering pump
AC Compressor
Alternator
If you notice more vibration when the AC kicks on, I would suggest checking the AC compressor. Since there is so much room in front of the engine, might as well pull the belt off and check all of the components for any sign of wear in the bearings. Put your hand where the belt normally sits and spin it. Try and feel if it moves smoothly or there is some looseness or grinding sensation. The bearings inside do not last forever and being exposed to the engine heat, I am sure after 17 years the grease inside is no good anymore. Fyi, I have the same engine and I have replaced everything listed above except the alternator....yet.
Old Jun 23, 2021 | 10:34 PM
joe5000's Avatar
E320 4Matic
Power Steering pump
AC Compressor
Alternator
what i find strange with mine is that the vibration is under my seat and after replacing my harmonic balancer there a slight wobble in the balancer my mechanic sais that's normal but i still say its not, and yes when i turn on the AC or heating there is more vibration. but after changing the transmission mount i notice i don't have vibration while driving anymore now its when i put the car on Park or neutral.
Old Jun 24, 2021 | 11:48 AM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
When manually shifting geats P to R or D, in my case was the front flex disc (guibo). Upon inspection it looked almost new, but when removed had cracks around every bolt hole. Changed it out and the difference was amazing.
Old Jun 24, 2021 | 01:33 PM
tjts1's Avatar
C320
Don't over think it, put Lemforder mounts in it.
Old Jun 25, 2021 | 10:45 PM
joe5000's Avatar
E320 4Matic
ill check into that.
when i bought the car it was driven by an old man he didn't even know what engine mounts where i took out the old mounts lets just say the metal was all chewed up there was no mounts left -_-.
it was actually a good thing it wasn't driven for 2 years
