E-Class (W211) 2003-2009
Transmission VGS #
Old Jul 10, 2021 | 11:18 PM
Hiltsjr42's Avatar
2005 E500 Sport
Transmission VGS #
I’m trying to order a 722.9 valve body and conductor plate how do I know the VGS number without taking it off my car. Also need to know what the pin connector size is . 2005 e500 base w sport/pkg
Thank You In Advance
Old Jul 11, 2021 | 11:39 AM
konigstiger's Avatar
'71 Pinto
If original valve body is part # 2202701206, control module 0002702600 = 5-pin connector & VGS3.
Not to confuse the matter but membership FYI: 4-Pin vs 5-Pin - originally manufactured with 5 electrical pins, the replacement part may have only 4 pins. The 5th pin was never used, and the 4-pin version is correct.
Old Jul 11, 2021 | 04:27 PM
Hiltsjr42's Avatar
2005 E500 Sport
Not sure what part numbers I have I’ve never looked at them. So are you saying I have the vgs3 version
Old May 29, 2024 | 06:22 PM
Amg_boy's Avatar
2008 w204 c63
Vgs2 or 3 2008 w204 C63
Hello,
My car is a 2008 c63. I want to replace the tcm as I have a fault code Y3/8n4 which I believe is the processor fault.
How do I know if my existing tcm is 4 or 5 pin without removing it first ?
