E-Class (W211) 2003-2009
Looking for tips regarding replacing the rear door.
Old Sep 5, 2021 | 12:06 PM
Jlindsey86's Avatar
Mercedes E350, Jeep Comanche, Triumph America
I am about to replace the driver's side rear door on my 2009 E350. I have a Donor 2008 with a perfect door.
  • The 2009 is a base model while the donor 2008 has Keyless Go. I will be using the base model's door handle. Will the 2009 car be able to lock and unlock the door from the 2008 once it is installed?
  • What is the best method of detaching and reattaching the door? It appears I have 3 options: (1) Remove the bolts where the hinges attach to the "B" pillar, (2) Remove the bolts where the hinges attach on the door, or (3) Just remove the hinge pins and lift the door up and off. Is any method better than the other?
Old Sep 6, 2021 | 03:15 PM
Jlindsey86's Avatar
Thanks for the tip. Would also love to hear of any first hand experiences if anyone has attempted this in the past.
Old Sep 6, 2021 | 09:55 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
It's a breeze. In the picture you posted - the bottom black piece is a plastic cap. One at each hinge - take off those plastic caps and remove the nuts underneath. Remove the bolts at the body for the tension bar. Be careful not to close the door against it, unless it's mounted. You'll damage the body. Remove the ashtray complete assembly and you should be able to disconnect the wires coming into the door to the SAM. Remove the accordion carrying the wires to the door and pull the wires through. Lift off the door. Swap the goods that you're looking to swap and put the new door on the same way and very carefully check for alignment and go from there.
Old Sep 7, 2021 | 11:56 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 7, 2021 | 06:57 PM
Jlindsey86's Avatar
See attachments.
Thank you for this!
Old Oct 5, 2021 | 11:40 PM
rbm's Avatar
rbm
2008 E300 4MATIC
Are there PDFs for the same replacement operation on the front door? I am in the same situation as the OP except needing to replace the front left door on my 2008 E300. I have the donor door but want instructions for the replacement process.
Old Oct 6, 2021 | 11:26 AM
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Oct 6, 2021 | 05:14 PM
rbm's Avatar
rbm
2008 E300 4MATIC
Thank you very much!!
