Visit Workshop battery sign
Lately I`ve got a red warning sign telling me "Visit Workshop" with a red battery sign on it. I`ve changed the main battery, and checked the small battery in the front, which is good.
Still, the sign won`t go away. Anybody got any idea what the problem can be?
Thanks.
Thanks.
Turns out the harness had been whipped/pinched against front t-case/destroyed from my "front driveshaft u-joint explosion debacle of 2020".
Couldn't even see the issue until i had removed the exhaust and alternator.
You need actual fault codes or you'll never find the reason for the fault or no charging.
The batteries charge through the starter BTW, as if that makes any sense at all.
119k miles
2004 e500 4 matic wagon
black on black
matthew
