DPF pipe A2114911137
I talked with every Mercedes in Austria / Germany about the part it is no longer made by Mercedes.
I have a part on order from a 2008 E220 om651 that hopefully might work as the flared nuts look to be the same size.
The issue is the flared nut disintegrated from rust that connects the pipe to the dpf , I'm hoping I can just take the flared nut off once I get it to put it on the original.
So does anyone know where I can ...
Get a new A2114911137 ?
Get a used one, and or where ?
Know the size of the flared nut and or where to buy it ?
Things are a lot different in Europe then USA where I own the same car but it does not have a DPF .
Thanks in advance
Just for reference . part is circled
This is the fitting I need the nut to go on. Not actual om648 dpf/cat just for reference
A2114911137 This part is no longer made by mercedes w211 e320 om648 European models with dpf/cat muffler .
Thanks but i need the part number #540 it looks like the image below (not actual part but close ) , you'll see how it has the nut that allows it to tightened onto the dpf
Awesome thank you very much ! I ordered it ! Should be the same size . Hopefully can find the other also somewhere
Just so everyone knows what I was talking about
