E-Class (W211) 2003-2009
W211 left brake light won’t go off.
Old Dec 16, 2021 | 01:09 PM
Rukowh's Avatar
E55, E350, C230k
I have an 04 E55 with the drivers side led brake light stuck on. I’ve searched on a few forums and found nothing. I don’t have any codes for anything electronic or light related. I replaces the bulb backing plate with a new one that I already had and replaced the pedal switch with new as well. Is there a relay that splits the left and right circuits somewhere? When I unplug the led, a backup bulb comes on.
This light stays on whether the key is on or off. The right brake light works correctly.
Old Dec 16, 2021 | 01:58 PM
konigstiger's Avatar
'71 Pinto
Check connectors/pins to rear SAM, see attachments.
File Type: pdf
File Type: pdf
Old Dec 16, 2021 | 05:30 PM
Rukowh's Avatar
E55, E350, C230k
Thanks for your reply. It seems that it’s all plugged in.
It turns out that my right side led stop light is not working. Not sure how that could make the left stick on. It’s odd because the left led light is on without the key being on. The lower brake lights only work with the key being on. I’m gonna check out the right led and see if it’s burnt out or bad wiring first.
Old Dec 16, 2021 | 06:55 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Would you.mind posting a picture of the back of your vehicle? With and without pressing the brake pedal.
Old Dec 19, 2021 | 12:19 PM
DuhStig's Avatar
E320 CDI
Had this happen once . the light switch was left on . put back on to auto, problem solved .... Hope it helps
Old Dec 20, 2021 | 12:54 PM
Rukowh's Avatar
E55, E350, C230k
thanks, but that’s not it. It’s only the left upper led brake light. The running lights are not led. I’ve since discovered that the left one isn’t working. The led is good but it’s not getting a signal. The lower brake lights work normally. I tried posting pics but for whatever reason they won’t post.
Old Oct 7, 2024 | 09:44 AM
danielgetsthis's Avatar
2005 E320 CDI
Did you figure this out? I'm having the exact same problem, including the error on the right side.
