E-Class (W211) 2003-2009
04 E320 help
Old Jan 18, 2022 | 05:02 AM
Ltlcar's Avatar
1990 500sl
04 E320 help
Good Morning,
I just bought a 2004 e320:with 75,000 miles. It’s is in good shape. When I bought it the car would start run for a a little bit rev up and shut down. No engine codes. The esp light comes on. I replaced the CPS and the MAF. Didn’t help. I have a Icarsodt pro scanner.it read the steering angle sensor was out at 6 degrees. I replaced that and the clock spring because that cracked. Car started ran for ten minutes, shut off now nothing. Starter not cranking. I did notice the starter sounded like she was going out. Any ideas would help! Thank,you
