E-Class (W211) 2003-2009
Knocking sound from w211 engine while idle
Old Jan 22, 2022 | 09:08 AM
Tayfun's Avatar
W211 2002 e220
Knocking sound and loud w211 engine while idle
Hi, in the attachment i tried to record the engine sound it makes, this sound was after driving on an autobahn doing a bit speed so warm engine, EGR was cleaned recently, injectors were checked a while ago but that time it was still making the sound so might not be injectors. I got glow plug malfunction but the sound from glow plug is only at the time i start the car i believe...
Not sure how will sound in audio file, but the engine is very loud.
Any ideas what this sound could be ?
W211 e220 2002
File Type: mp3
Old Jan 23, 2022 | 01:22 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
The knocking sounds just like my E320 cdi. Are you talking about the chuffing sound?
Failed glows won't make a sound but can cause a rough idle for a few seconds before the cylinder heats enough to ignite the diesel and even that is only an issue at colder temperatures.
Have you removed the serpentine belt and spun accessories by hand, including the pulleys and tensioner?
Old Jan 23, 2022 | 06:34 PM
Tayfun's Avatar
W211 2002 e220
It's more like, the engine is being too loud compared to how it is supposed to be, which can be pretty disturbing, I did not try that actually, is it possible to find the source like that, i had some pulleys and the belt replaced recently
Old Jan 23, 2022 | 06:53 PM
2013 ML350 Bluetec
The serpentine belt can be inspected for odd wear patterns (might be the source of the chuffing sound) and everything the belt touches can be spun by hand to listen for odd noises.
Did the noise you're noticing begin after the pulley and belt replacement?
The engine noise in the video, to me at least, sounds normal.
Possible you have an exhaust leak? Might be able to amplify that by having a willing assistant loosely cover the exhaust tips while the engine is running then see if you can notice anything under the hood.
Old Jan 23, 2022 | 08:48 PM
dvenneman's Avatar
E350 4matic Wagon
Could not hear knocking sound
W211 e220 2002
could not hear it. Sounded good to me - maybe a bit of air leak at exhaust?
Old Jan 24, 2022 | 08:48 AM
Tayfun's Avatar
W211 2002 e220
the sound was there before the replacements too, just did not know why, the sound is not always same but sometimes gets really loud, i have attached one more audio now to this comment might be more clear now
File Type: mp3
Old Jan 24, 2022 | 08:49 AM
Tayfun's Avatar
W211 2002 e220
sorry i realised it is not that clear as you said, i added a new sound to this comment if you would like to listen, i think it is more clear, it's like it keeps hitting something as it runs if you know what i mean and the sound is really loud
File Type: mp3
