Automatic Climate Control Hot - Cold - Hot
I read somewhere that this could be the interior temperature sensor, of which there is one near the ignition key, and frequently reference is one at the top dome. I tried the tissue test up around there but nothing stuck, but the ignition grille did hold the tissue. With the automatic systems taking all this input, not sure if anyone has had these exact symptoms in the winter. I can probably pop out that sensor to clean, but any other rundown of diagnostics I should look for?
Anyone have the part numbers for the sensor on the top dome? If that is indeed the issue.
https://w220.wiki/Overhead_Control_Panel_(OCP)_(N70)
Finished product. No more 0 reading , but temperatures were above 50 today so I think the dash sensor is used. Used https://www.benzworld.org/threads/ov...#post-13910849 as a template.
