E-Class (W211) 2003-2009
Will w220 amg wheels work on w211
Old Mar 18, 2022 | 05:31 PM
Russbus's Avatar
2007 E350
I have an 2007 E350…..Current set up is staggered 8.5x18 et38 front and 9x18 et39 rear. Am looking to replace with 2003 S500 amg with 8.5x18 et44 front and 9x18 et46.
I guess I could reluctantly use 5mm spacers to satisfy offset, but am unsure of other problems like bolt length, thread, etc. I certainly would appreciate any feedback from anyone using w220 wheels on a w211. Thanks
Old Apr 3, 2022 | 01:31 PM
Pauliefein's Avatar
2004 E55, 2006 E500 wagon, 2014 E350
If you add 5mm spacers, you wont have any issues with lug studs. If not, I'd be just slightly concerned with the lug studs touching the emergency brake gear behind the rear rotors. It's probably not an issue, but worth being prepared to buy shorter studs. I'm sure the rim will clear the calipers. I did a similar swap on my wagon. I added 15mm spacers and longer lugs. Here's my post.
https://mbworld.org/forums/e-class-w...500-wagon.html
