Jack stands ONE corner at a time
Doing brake work for the first time and would like to just raise the corner I'm working on, in this case the rear corners. I've searched and read a million threads/posts on this topic but haven't found one specific to this car or one very close to it. And there are a million ways people have jury rigged things. I just want a simple way to jack a corner and place a stand. The simplest method I've see is to jack at the front jack pad and this will raise the entire side of the car. Then place jack stand under rear jack point. Seems simple, but:
Ia this OK to do (twist frame?)?
Once the stand is under the back, do I need to support the front? How? Leave floor jack in place?
I appreciate any help
And is it really OK to jack off the control arm?
If somehow it feels uncomfortable doing that, lift the corner by jacking at the nearest lift pad. Then place a jack stand with a block of wood spacer under a suspension cross member mounting point.
I have a lift at my house so I always life the entire car up. But just as mentioned. Lift the front end and support BOTH sides with jack stands so the front end is up. And or do the same in the rear. I would not lift just a single corner up. It takes the same effort to lift a corner as it does the front and have it stable on both sides and supported properly.
It's not worth something happening and the car comes down on the one corner. You normally get once chance with accidents when it comes to vehicles coming down. I'd prefer to not use that one chance up in an event something happens.
-Nigel
Peter
It's one of those things that to me it's not worth it... if the car shifts or for whatever reason something is under where you are jacking up the car and it falls and now your body part is under or around it, asking for a quick and possibly serious injury not counting if the car ends up breaking something.
-Nigel
-Nigel
