ive had this issue with the bottom transmission line popping off for a while and i just changed the o-rings not sure why its still having this problem maybe i didnt use the exact oem o-ring not too sure need some help.. im gonna try and attach a video to this thread so you can see the issue
I used a Hayden transmission cooler on my Mercedes. Here's some pics from my C320. My E320 is very similar.
very happy with the results. https://imgur.com/a/W7iZf
so would i just leave the 2 slots in the radiator open
yup that's exactly what I did. The c320 used the exact same type of clip connector in the radiator and the upper line kept popping out. Something had to be done and later I did the same thing to the E320. Here's the E320 with the Hayden 679 trans cooler. You can feel the heat pouring off that thing after a drive.
