2009 E 350 Low compression cylinder 5 and 6
All,
I have a 2009 E350 which will not pass smog because cylinder 5 has a misfire, I changed all the parts, injector, coil, Spark Plug, still misfire. I had a compression done and cyldinger 5 is at 120 and cylnder 6 at 125, mechanics keep wanting to pull engine and replace both heads or replace the entire engine. Can these the one head be removed and fix the problem. Anyone deal with this before, and if so how do I go about trying to fix it with out swapping out a whole engine.
