Will this 19" wheel fit W211????
They came off an s class and the make of wheel is Antera with the stamp 95JX19H2ET32
Marc
Depending which S-class they came off of (probably not a W220 S-class), the lug bolts can be different sizes. As long as the holes in the wheels are drilled to clear 14mm bolts of the W211, then they should fit.
The W140 S-class also uses 14mm bolts, and it would also fit 9.5" wide wheels ... the W126 S-class uses 12mm bolts, and 9.5" wheels area better fit, with an offset of ET25-33 being a good range.
I have numerous wheels that will not fit the W211 because the 14mm bolts won't fit through the holes...
-s-
