Help: Door lever does not unlock the door
Advance apologies. I did a search but couldn't find a thread that talks about the problem I'm having with my 08 E350. Perhaps I'm not using the correct set of keywords.
At any rate, all doors lock and unlock with the keyfob and also with the lock/unlock button on the dashboard.
The problem is that when locked, all but the driver side door does not unlock the door when you gently pull back on the lever inside the door handle.
I have to either use the keyfob or pull the level inside one of the other doors to unlock the car.
And here's an interesting thing. A few weeks ago, the front passenger door was doing this. Now it is working but the front driver side door now has the problem.
Perhaps there is a sequence one has to push on the keyfob to reset the door(s) or on the instrument panel?
Any help would be appreciated.
Many thanks.
