E-Class (W211) 2003-2009
W211 sound issues
Old Apr 29, 2022 | 01:19 PM
theauxify's Avatar
W211 e500
W211 sound issues
So i have a strange issue that i can’t get to the bottom of. I have the 810 option on my car wich means i have the harman kardon audio system, basically there is a strange radio static no matter what i do, radio and an fm modulator both having this issue, the vocals just sound like there was radio interference or something , i have already checked the antenna amplifier and other basic things but i have no clue to where to even start looking , maybe someone has an idea
Old Apr 29, 2022 | 02:15 PM
jason556's Avatar
2007 e350
Following this--I have the same issue. Everything sounds like bad radio static. And I'm sure it's not the antenna because I have an old iPod hooked up to mine and it still sounds the same. Car's been sitting for 2 years and I don't know if some wiring went bad.
Old Apr 29, 2022 | 02:26 PM
theauxify's Avatar
W211 e500
Hmmm i see , i hope we can get to the bittom of this , because i would like to enjoy my music without static going to do some research on the audio gateway and head units .
Old Apr 29, 2022 | 02:56 PM
jason556's Avatar
2007 e350
I'll try to do the same. Please let us know if you find anything. I'm not very good with audio and electrical but I'll see if there's anything online.
Old Apr 29, 2022 | 03:39 PM
theauxify's Avatar
W211 e500
allright will keep you updated
Old Apr 30, 2022 | 06:25 AM
theauxify's Avatar
W211 e500
so i confirmed that the static noise is only when using radio fm function, burned a cd and boom no static at all, all sounds really amazing .
so its going to be something that has to do with radio.
Old Apr 30, 2022 | 09:41 PM
konigstiger's Avatar
'71 Pinto
May be caused by bad ground, see attached bulletin (no need to replace bracket).
File Type: pdf
Old May 1, 2022 | 12:12 PM
theauxify's Avatar
W211 e500
i checked the agw , the amplifier its self was loose from the bracket , i removed the bracket , tightened the agw , then removed the plug as instructed and tested resistance , showed me 0.04 ohms , since it was nothing close to 1 ohm i put everything back together thinking that tightening the agw would fix this issue , and that it was the reason that the ground was bad or something but still no, the issue persists.
Old May 2, 2022 | 01:43 PM
theauxify's Avatar
W211 e500
Bump, anyone here got any clue ?
Old May 5, 2022 | 09:30 AM
theauxify's Avatar
W211 e500
Is there any way to factory reset everything on the audio system?
Old May 6, 2022 | 01:46 PM
shertex's Avatar
1991 300D, 2006 E320 CDI, 2014 E250 Bluetec
I have the same issue. For me it's with both radio and using the 3.5mm input. Extremely annoying. I took it to Best Buy but they wouldn't touch it...said I need to take it to someone who specializes in Mercedes audio....or the dealer. So for now have given up and am just using a Bluetooth speaker.
Old May 7, 2022 | 04:06 AM
theauxify's Avatar
W211 e500
hmm, sorry to hear that, but i appear to have a similar but different problem, i might be looking at something connected to antennas or something like that. I just have no clue to where to look and nobody can answer my question the audio i have from cd is amazing , but radio is really terrible
