E-Class (W211) 2003-2009
Keyless Go Intermittant?
Old Oct 3, 2004 | 11:27 AM
Barry45RPM's Avatar
2015 ML 350
Anyone ever gotten into the car & pressed the start button only to have the car crank only for a half a second & stop cranking without starting? It stopped cranking as if the battery went dead.
Sometimes I press the button to go back to the the off position, then try again & it starts normally. Today when it happened, I tried again & it wouldnt crank at all by pushing the start button... I thought maybe I wasn't pressing on the brake hard enough to get past the brake bedal switch, but no...
I had to start it with the key. It cranked quickly & started
Old Oct 3, 2004 | 11:30 AM
levind's Avatar
Check with your service advisor. I believe there has been a tb issued for intermittant starts. This has nothing to do with the kg.
